2001 Ford Taurus Intermittent No Start
WISHITWASACHEVY
I'm new here, but I appreciate all the help others have gotten. I've worked on many cars before, but this one is stumping me.
Lately, my 2001 Ford Taurus will not start. It cranks, but is not getting fuel. When the key is turned, the fuel pump does not prime (no humming), and won't start. Then after just trying a few times, it will humm, and start right up.
I'm trying to narrow down what is causing this, before just replacing the fuel pump, to avoid the cost if possible.
I checked out the relays, and they are operating correctly, but was wondering if they would do this intermittently?
Any advice is greatly appreciated, it's cold up in Wisconsin!!!
Dec 12, 2006 at 4:06 AM
CATCH_15
  • 250 POSTS
A way to test it the fuel pump is mechanically failing is to run a fuel pressure test. If the fuel pump is good, you should get a reading anywhere between 30 and 65 psi of pressure.
Dec 12, 2006 at 4:39 AM
WISHITWASACHEVY
I changed out the fuel pump relay, and thus far, the problem has not occurred since. I am hoping the life of the relay was simply starting to go, and occasionally the contacts stuck. I'll give an update in a few days to let people know if it worked or not, in case they run into the same problem. It's much less painful changing a $5 relay, than a $300 fuel pump.
Dec 14, 2006 at 12:52 AM
Suggested Repair
Confirm fuel pressure is about 30-65 psi if the no-start returns. The reported fix was replacing the fuel pump relay, which stopped the intermittent no-prime condition.
Conversation Summary
A 2001 Ford Taurus sometimes cranked with no fuel-pump prime, then primed and started after several attempts. The owner had checked the relays. An expert recommended a fuel-pressure test of 30-65 psi to check the pump. The owner then replaced the fuel pump relay, and the problem had not returned.
