1999 Ford Taurus P1309 Misfire
SILVERTABB
This car has a V6 engine (SE model), and over 120K miles. CAM Shaft was changed along with the spark plugs/wires, radiator sensors. The engine light came on again and the same code was generated. As a last resort, PCM was changed. The engine light disappeared and the next day after driving the car for over 1 hour, I took it in for smog test. It passed smog test. Later the same day, the light came on again and this time the code are for misfire (P1309) and bad downstream Oxygen Sensors. I need help.
Jun 22, 2007 at 6:42 AM
MERLIN2021
  • 17,250 POSTS
P1309 Misfire Monitor Hardware - CMP Misaligned, CKP/CMP Noise, PCM AICE Chip F G Try restting the crank sensor it' seems to show misalinment...
Jun 23, 2007 at 1:48 AM
Suggested Repair
Reset or reseat the crankshaft position sensor and check for crank/cam sensor misalignment or signal noise, since P1309 points to misfire-monitor hardware issues involving CMP alignment, CKP/CMP noise, or the PCM.
Conversation Summary
A 1999 Ford Taurus V6 with over 120,000 miles had a recurring check-engine light after the camshaft, spark plugs and wires, radiator sensors, and PCM were replaced. It passed a smog test, then the light returned with P1309 misfire and downstream oxygen-sensor codes. The expert linked P1309 to misfire-monitor hardware, CMP misalignment, CKP/CMP noise, or the PCM, and suggested resetting the crank sensor.
