Hi, I have a 1998 Ford Taurus SE with 116000 miles. It is an automatic with a 3.0L DOHC Duratec motor. I recently changed the plugs and wires, have switched to synthetic oil two oil changes ago, and within the last 16000 miles replaced the speed sensor on the transmission due to failure of the previous one. After driving in reasonably warm weather then letting it sit for 5 hours, I started it up but I got a drastic reduction in idle (usually around 800 RPM but it dropped to below about 400) and when starting from a stop I got a hesitation almost like the engine had no gas before it caught and returned to "normal." Driving at higher speeds the transmission shifted at odd times. Shifting into neutral at low speeds the engine would jump to around 3000 RPM but tapping the pedal would lower the RPM's to normal for that speed. The engine ran very rough when I stopped and nearly stalled when left to idle for 2-3 minutes only to run very rough at very low RPM's after that. Any help with what may be the problem would be greatly appreciated. Thanks
Jun 2, 2007 at 3:58 PM
