2000 Ford Taurus Misfire Under Acceleration
NATE.MAYO
I have recently purchased a 2000 ford taurus with 115000 miles and have a problem I hope you can help with. It is a 2000 model year with 115000 miles and a 3.0 litre non OHC engine. The situation is that the engine misfires under acceleration when you shift into passing gear. To accompany this problem it seems to misfire, but not as dramatically, when you are cruising at 55 mph. I am sure these are the same problem. I am suspicious of the coil pack or mass air sensor. Can you offer any suggestions
May 7, 2007 at 5:02 AM
MERLIN2021
  • 17,250 POSTS
Take it to autozone, they will test the coil for free. Leave it in the car!
May 7, 2007 at 7:06 AM
KURTP190
may be torque converter shudder at that speed start with trans flush
May 7, 2007 at 12:35 PM
Suggested Repair
Have the ignition coil pack tested while it remains installed, such as a free coil test at a parts store.
Conversation Summary
The owner of a 2000 Ford Taurus with a 3.0L engine reports misfires during hard acceleration and milder misfires while cruising at about 55 mph, suspecting the coil pack or mass airflow sensor. An expert advised having the coil tested in the vehicle at a parts store. Another participant suggested starting with a transmission flush in case the symptom is torque-converter shudder.
