2001 Ford Taurus Cylinder 5 Misfire
RALENE38
I recently had my lifters replaced, It ran very well then started to hesitate up hills it was placed on a computer and it said p0305 cylinder 5 misfire detected. I have checked my plugs and wires, and the car is using a lot of coolant? What is a cylinder 5 misfire if it is not the plugs and wires? it has 111,000. miles on it mostly highway miles.
Jun 9, 2007 at 10:33 AM
SERVICE WRITER
  • 9,123 POSTS
Using coolant and misfore may me wonder if the headgasket is a problem causing the misfire. Pull the #5 plug and look at it. crank the engine with that plug out and see if it is shooting out coolant.
Jun 9, 2007 at 2:34 PM
Suggested Repair
Remove the number 5 spark plug and inspect it. Crank the engine with the plug out and check whether coolant sprays out, which may indicate a head gasket problem causing the misfire.
Conversation Summary
The owner of a 2001 Ford Taurus with 111,000 miles reports hesitation on hills and a P0305 cylinder 5 misfire after recent lifter replacement. The plugs and wires were checked, and the vehicle is using a lot of coolant. The expert suggests a possible head gasket issue and recommends removing the number 5 plug and cranking the engine to see if coolant sprays out.
