1990 Ford Taurus Split CV Boot
THINGONE03
i have a 1990 ford taurus v6 3.0 with 85,000 miles. my cv boot is split and i need to replace it. what tools do i need to do this? and should i replace to joint too?
Apr 5, 2007 at 4:41 AM
PEPPERMRJ
  • 1,158 POSTS
Does the cv joint click in tight turns? If so it does need replaced. If not you could try a split boot repair kit which is much easier to do with minimal tools. You cut away the old boot, clean the joint, regrease the joint, and install the boot.
Good luck and let us know. :)
peppemrj
Sep 30, 2018 at 5:52 AM
THINGONE03
i haven't noticed any clicking but the cv joint on the passenger side went out last week, so i'm a little paranoid of ANY sound i hear now. can i go to any auto parts place and get a split boot repair kit and does it come w/instructions and tell you what tools are needed for the repair?
[quote:0e74584a84="peppermrj"]Does the cv joint click in tight turns? If so it does need replaced. If not you could try a split boot repair kit which is much easier to do with minimal tools. You cut away the old boot, clean the joint, regrease the joint, and install the boot.
peppemrj[/quote:0e74584a84]
PEPPERMRJ
  • 1,158 POSTS
[quote="thingone03"]i haven't noticed any clicking but the cv joint on the passenger side went out last week, so i'm a little paranoid of ANY sound i hear now. can i go to any auto parts place and get a split boot repair kit and does it come w/instructions and tell you what tools are needed for the repair? Yes, should be at any parts house and come with complete instructions. It is basically a boot that is split in half. You remove the old boot, clean the joint, and grease it. The new boot is then installed.I put one on my father in laws car and it was there 50,000 miles later when the timing gears went and we junked it. Good luck and let us know. :) peppemrj
https://images.2carpros.com/forum/automotive_pictures/4270_split_boot_1.jpg
CRAIGFL
  • 89 POSTS
Speaking from experience with this kind of split boot:
1. Important to clean joint VERY good
2. Important to put lots of new grease back into it
3. Important to install boot so parting surface and screw holes are absolutely clean. If you get grease on the surface and in the holes an tighten the screws, you risk spinning the parting surface and tearing the holes in the rubber out.
4. Best to glue parting surface for better seal.
Suggested Repair
If the CV joint does not click during tight turns, use a split boot repair kit from an auto parts store. Cut off the old boot, thoroughly clean the joint, pack it with plenty of new grease, and install the split boot. Keep the parting surfaces and screw holes completely clean, and glue the parting surface for a better seal. If the joint clicks, replace the joint rather than only the boot.
Conversation Summary
The owner of a 1990 Ford Taurus with a split CV boot asked which tools were needed and whether the joint should also be replaced. The expert said a clicking joint should be replaced, but otherwise a split boot kit is easier and requires minimal tools: remove the old boot, clean and regrease the joint, and install the new boot. The kit should be available at parts stores with instructions. Another contributor stressed thorough cleaning, ample grease, clean mating surfaces and screw holes, and gluing the parting surface.
