1992 Ford Taurus Runs Rich
HUACHUCADAVE
Since I didn't get any replies on my question of getting my mpg back up to the 30+ mpg range I'll see if I can ask a related question that may answer my first one.
I've noticed that my 92 Taurus wagon has been running rich - I can smell unburnt fuel at idel and other times. I'm guessing that whatever is causing my engine to run rich is also what's causing my loss of miles per gallon.
I've read some about the many sensors and how they interact. I've changed the two O2 sensors on the exhaust manifold, gently cleaned the Mass Airflow Sensor, changed the cap and rotor, changed out the ignition coil and changed to a K&N air filter all with no effect.
Would it be worth the money spent to take my car to the dealer - does the dealer in fact have the best diagnostic machine - to see if any of the sensors show up as malfunctioning?
Jun 12, 2006 at 9:39 AM
TAURUSWHEEL
  • 718 POSTS
First thing, go buy yourself a $30 eec4 code scanner, Actron or some other brand, and learn how to use it, it's simple, not a fix-all, but every car owner should have one, either obdI (yours) or obdII, depending on your model year.. secondly, take a fuel pressure reading, any black smoke from your car??? If it's rich as you say, there must be some sign of the extra fuel.. Any leaks??? That K&N filter, is it the oiled one?? If it is, get rid of it, will only foul out the maf sensor... the problem with computer codes for obdI, check engine light may not necessarily come on, even if the sensor is not at optimum performance. Only when certain parameters are not met will the light come on,,, your system is not at all comparable to the newer, 96 on up, obdII.. much more detailed is the newer.....my own recent example of no cel, my trans was shifting weird in my 94 Taurus, no light, however there were 3 codes in the hard memory related to shift issues...back to your issue, any misfiring noted??? That would be a reason to have someone do a scope of the ignition system if plugs, wires didn't fix it,, of course it could be fuel-related misfire... another good thing about the little code reader is you can run a cylinder balance test where the injectors are shut down in sequence, one by one, while the pcm looks for a specfic rpm drop, you'll be alerted by codes if any cylinder looks suspicious... as far as o2 sensors, only ever replaced one, on 87 Taurus, because I got a code indicating a lean issue, turns out the sensor wasn't the problem, the dedicated ground for the sensor was,, I couldn't figure that problem out for nothing, lucked into a Ford mechanic who told me to check the dedicated ground, even told me where it was, I had noticed that orange wire millions of times, had no clue what it was for,, loosened it up, cleaned it, just like new... only reason, for me, to even think of changing o2's would be if they weren't switching voltages quickly enough, in which case, especially with obdII, you would get a light,, older cars such as yours might not necessarily light up, only if a rich or lean condition doesn't meet the less stringent parameters set in the pcm.. go get yourself a code reader, fuel pressure gauge, maybe a compression tester,, 3 tools that can take you a long way with any car.. probably talking $125 for all,, reader will work up to 95 model year with obdI, I believe some 95's may have been obdII, not sure of that, however a obdII reader can be had right here on this site for what??? $70 or so???,, the other 2 tools can be used, with adapters, on most any domestic car, probably most foreign.. Good luck
Jun 12, 2006 at 1:32 PM
Suggested Repair
Scan the EEC-IV system with an OBD-I code reader, including a cylinder balance test, and check fuel pressure and compression. Look for black smoke, fuel leaks, and misfires. Remove an oiled K&N filter if fitted, because it can foul the MAF, and inspect the dedicated O2 sensor ground.
Conversation Summary
The owner of a 1992 Ford Taurus wagon reports a rich-running engine, unburned fuel smell, and reduced MPG after replacing both O2 sensors, cleaning the MAF, and changing the cap, rotor, coil, and air filter. The expert recommends an OBD-I code reader, fuel pressure and compression tests, checking for smoke, leaks, and misfires, and removing an oiled K&N filter that can foul the MAF. They note OBD-I may store codes without lighting the check engine light and that a poor dedicated O2 ground can mimic a sensor fault.
