1994 Ford Taurus Brake Thump
RKEMP98
My 1994 Ford Taurus with auto transmission and 162000 and a 3.8L engine occasionally thumps when I use the brakes to stop and when I release the brakes after they thump stopping will thump again. I did notice low brake fluid level.
Nov 11, 2007 at 1:51 AM
MERLIN2021
  • 17,250 POSTS
Check the condition of the rotors, pay attention to pitted and rusted areas on the inner and outer surfaces...if low on fluid, it means it's time to replace at least the front, and possibly the rear brakes! Inspect all 4 wheels!
Nov 11, 2007 at 1:55 AM
Suggested Repair
Inspect all four wheels and the brake rotors for pitting and rust on the inner and outer surfaces. Low brake fluid indicates worn brakes, so replace at least the front brakes and possibly the rear.
Conversation Summary
The owner of a 1994 Ford Taurus reports occasional thumping when applying the brakes and again when releasing them, along with a low brake fluid level. The expert advises inspecting the rotors for pitting and rust and replacing at least the front brakes, and possibly the rear, after checking all four wheels.
