1998 Ford Taurus Brakes Grinding
RUNNING_GUY08
  • 9 POSTS
I have a 1998 Taurus V6 3.0 with 119,000 miles. I changed the front brakes almost 2 months ago myself and had no problems for about 2 weeks. The weather started to cool down to under 100 ( I live in PHX) and the brakes started making grinding sounds, but only the first time or 2 that I press the brakes. I took both front tires off and visually checked the pads and the rotors and they are the correct distance away from the rotor and there are no visible scratches on the rotors themselves. The calipers are screwed down plenty tight enough on both sides as well. The new pads are metallic and I don't know if it is just them breaking in or it is normal for metallic pads but I dont want to take any chances on ruining something. Any Ideas?
Nov 15, 2007 at 8:38 AM
MERLIN2021
  • 17,250 POSTS
Semi mets are like that, if it bothers you, do what I did with my Sable, change to Ceramic...
Nov 15, 2007 at 10:01 AM
TAURUSWHEEL
  • 718 POSTS
Get autozone 15 dollar duralast pads, cheap and quiet
Nov 15, 2007 at 11:04 AM
RUNNING_GUY08
  • 9 POSTS
Sounds like a good idea to me. So, the grinding that I am hearing isn't harming any of the brake components correct? What causes the sounds? just the brakes warming up?
Nov 15, 2007 at 2:47 PM
MERLIN2021
  • 17,250 POSTS
It's a moisture problem, the rotors get wet with dew and semi mets are loud while drying...not a saftey problem...Taurus and Sable front brakes run a bit hot anyway, should dry quick!
Nov 16, 2007 at 6:25 AM
Suggested Repair
The brief grinding is consistent with semi-metallic pads drying dew off the rotors and is not described as a safety problem. If the noise is bothersome, replace the front pads with ceramic pads.
Conversation Summary
The owner of a 1998 Ford Taurus reported brief grinding during the first one or two brake applications after cooler weather, about two weeks after installing metallic front pads. A visual check showed normal pad clearance, no rotor scratches, and tight calipers. Experts said semi-metallic pads can be loud while moisture on the rotors dries and that this is not a safety issue; ceramic pads were recommended for quieter operation.
