I have a 1999 Taurus with over 126,000 miles.recently i have heard a squealing/chirping noise . The noise stops if you apply the gas.
Dec 17, 2006 at 9:20 AM
With the engine off, inspect the serpentine belt for wear and cracking on the inner side. If the belt is replaced, spin all pulleys and driven components by hand to confirm they turn freely and make no noise.
The owner of a 1999 Ford Taurus with over 126,000 miles reported a squealing or chirping noise that stops when the accelerator is applied. The expert suggested a worn serpentine belt and advised inspecting it and checking that all pulleys and components spin freely and quietly. Another owner of a 2002 Taurus said a belt and idler pulley replacement did not fix a similar noise and that a dealership later replaced a bad camshaft synchronizer.
