3.0, 106,000 miles. New wires, plugs, fuel pump.
When at idle in park, idle moves up and down from just under 1000 to a little above 1000. I'm guessing from about 800 or 900 to about 1100 and back again. Moves up and down continuously at a steady pattern.
When in drive, and after driving it awhile, it idles smooth unless you set for about 2-3 minutes in drive with the brake on. It will then start moving around slightly and almost stalls at times.
Sep 1, 2007 at 11:47 PM
