1996 Ford Taurus High Idle and Rough Idle
KLBADKM
I have a ford taurus with 152,000 miles and this car had been very good to us until now i recently had to replace bank 2 oxygen sensor, and that took care of the ceck engine light, but some times my car after driveing home from work when i start to slow down coming into town it runs a high idle about 1200 to 1400 rpms, and at a take off from a stop it starts to chug is it my idle air vavle or my throttle vavle sensor, its really not snappy on the take off either. it also idle very rough at low idle. i checked the ecm and have no codes?
Jun 4, 2007 at 11:03 AM
RUDPRO
  • 224 POSTS
It's hard to diagnose without the computer setting a trouble code. The first thing I would check is your vacuum lines. Make sure there are no cracks or leaks and all lines are on securely. If that's OK, it could be your Mass Air Flow Sensor. They get contaminated where they don't work right, but not enough to set a trouble code. As you stated, it could be the Idle Air Control Valve or Throttle Position Sensor. Those could be checked with a digital multimeter. Check the vacuum lines first and post back if you would like to check the sensors.
Jun 4, 2007 at 11:58 AM
Suggested Repair
Check all vacuum lines for cracks, leaks, and secure connections first. If the lines are sound, test the mass airflow sensor, idle air control valve, and throttle position sensor with a digital multimeter, since contamination or sensor faults can cause these symptoms without setting a code.
Conversation Summary
A 1996 Ford Taurus with 152,000 miles had a bank 2 oxygen sensor replaced, which cleared the check engine light. It still sometimes idles at 1,200–1,400 rpm when slowing down, chugs and feels sluggish leaving a stop, and idles roughly at low speed, with no ECM codes. The expert recommended checking vacuum lines first, then considering a contaminated mass airflow sensor or testing the idle air control valve and throttle position sensor.
