96' Taurus LX problem
KZERSATZ
  • 1996 FORD TAURUS
96' ford TaurusLX 75'000 miles 17-21mpg
Starting the car it starts rough
idles rough
and if the ac/vent was running on the car I could smell gas fumes
the car idles around 500-700rmp which I know for this model car is very uncommon unless there is a problem
the check engine light isnt on though was on for about 10min about a week ago, turned car off and on and light vanished
my theory (im not in anyway a mechanic) from what ive read and heard from rumors is the car is starving for Oxygen considering im getting the smell of gasoline in the cab
oh also once I get moving there arent any problems when driving except once I hit the gas pedal the car shoots forward and jumps to the proper RPM when accellerating
any ideas? I need to get this solved quickly beccause I have some serious driving I need to be doing this weekend = /
Friday, August 17th, 2007 AT 9:50 AM
2CARPRO JACK
  • 11,533 POSTS
Look for external fuel leaks at the injectors first. Might be the fuel pressure regulator causing the initial rich condition at start up. Remove vacuum line fron reg and look for raw fuel, if present replace the reg
Saturday, August 18th, 2007 AT 7:38 AM
