1990 Ford Taurus Won't Start
BERNITA
1990 ford taurus v6 3.0 engine won't start thought it might be fuel line but pumps fuel maybe fuel filter
Mar 4, 2007 at 10:41 AM
NOS
  • 320 POSTS
Do you have spark?
how much fuel pressure do you have ?
have you tryed spraying carb cleaner into the intake to see it the car will hit. pull the hose off where the air cleaner connects to the intake and spray some carb cleaner in the intake quit a bit of it you will have to open the butterfly to get in the intake. then crank the motor. this will tell you two things if you have fire and it will tell you if your not getting fuel there. it the motor hits off the cleaner that answered the question of does it have fire. then that means you have a fuel problem. let me know 8) NOS
Mar 4, 2007 at 11:35 AM
NOS
  • 320 POSTS
The more info you give the better help you can get. 8) NOS
Mar 4, 2007 at 11:41 AM
BHUGG
  • 157 POSTS
Check all the fuses, both in the dash and under the hood. The fuse box under the hood also contains some relays. If all the fuses are good, try swapping out relays (the same type of relay).
Good luck.
Let the forum know what happens. We like feedback.
If we help, vote for those who deserve it.
Mar 4, 2007 at 3:55 PM
Suggested Repair
Check spark and fuel pressure, and spray carb cleaner into the intake while cranking to see whether the engine fires. Also inspect dash and under-hood fuses and swap same-type relays if the fuses are good.
Conversation Summary
A 1990 Ford Taurus 3.0 V6 will not start. The owner suspected the fuel line or filter even though the pump delivers fuel. Experts advised checking spark and fuel pressure, spraying carb cleaner into the intake to distinguish an ignition problem from a fuel problem, and inspecting fuses and relays under the dash and hood.
