1992 Ford Taurus Cranks No Start
OPTIMUS28
1992 Ford Taurus V6 3.0L 175000 miles I have replaced the spark plugs & coil, checked wires and distributor, the car is getting spark but when I try to start the car, it sits there and cranks and cranks but won't turn over. I have check the fuel pump you can here it running and the filter both working but it seems no gas is getting to the engine. I even called a Ford garage and he couldn't give any suggestion other than bring it to his garage so he could hook it up to his diagnostic machine. There's got to be something I'm missing. I was driving it home from work and it lost power for a second then came back running then a mile it did it again. I got it home but the next day it ran than turned off then it rough idled for a minute, tried to give it gas and it lost power then backfired. Today I tried starting it and it just cranks.
Sep 20, 2006 at 8:11 AM
CBASS655
  • 5 POSTS
You have said you checked the distributor but my 92 ford taurus did the same thing and it was the distributor. I took the cap off and turned the car on and the distributor wanst turning. It was because all of the gear teeth at the bottom were worn and chewed apart. Just thought i would let you know.
Sep 23, 2006 at 6:53 AM
BUBBA_KOSKI
  • 129 POSTS
on top of that first post with the gear teeth is true but check the fuel lines, and return lines
Sep 28, 2006 at 5:15 AM
Suggested Repair
Remove the distributor cap and crank the engine to confirm the rotor turns. If it does not, inspect the distributor drive gear for worn or missing teeth. Also inspect the fuel supply and return lines for leaks, restrictions, or other problems that could keep fuel from reaching the engine.
Conversation Summary
A 1992 Ford Taurus with a 3.0L V6 cranks but will not start after intermittent power loss, rough idle, and a backfire. The owner reports spark, a running fuel pump, and a working filter, but suspects fuel is not reaching the engine. A reply describes the same no-start on a 1992 Taurus caused by worn distributor gear teeth that stopped the distributor from turning. The expert confirms that possibility and also advises checking the fuel supply and return lines.
