2004 Ford Taurus HAVE NO BACK BREAK LIGHTS BUT THIRD LITE W
2004 FORD TAURUS
88,467 MILES • 6 CYL • 2WD • AUTOMATIC
LARRYTREEN
BREAK LIGHT IN BACK WINDOW WORKS AND FLASHERS WORK BLUBS ARE OK
Jan 26, 2010 at 12:39 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Welcome to the forum. There were several Taurus listed in the database, I looked at the LX. Also, there seems to be a difference in the wiring between the sedan and wagon. With the wagon, the lower brake lites are not wired through the multifunction switch. With the sedan, the voltage circuit for the lower brake lites ARE wired through the multifunction switch. Can you check for voltage and ground at the rear?
Jan 26, 2010 at 2:26 PM
