1995 Ford Taurus No Brake Lights Shift Fix
HUSKY
1995 Ford Taurus SHO with 185,000. Only 200 miles on rebuilt V-8 enigine. I can't shift my car out of park without going through the alternate steps listed in the manual and the brake lights dont work. I replace the fuse which unlocked the gear shifter which is in the middle console, but still no brake lights. After a few hours, the fuse must have blown again because now the gear shifter won't go. It's not the transmission. I seem to have an electrical issue. Anyway I can take of this in my driveway?
Oct 8, 2007 at 9:52 PM
CHEVY22
  • 1,375 POSTS
yes you can , the brake light switch located on the brake pedal sounds like it went bad , but the other switch called a boo brake on off switch may have also failed , the parts are cheap and real easy to replace , the brake light switch is the one to start with , this will fix the lights and possibly the shift interlock but you wont know until its replaced
thanks
jim
Oct 12, 2007 at 10:46 AM
Suggested Repair
Start by replacing the brake light switch on the brake pedal. It is inexpensive and easy to replace and should restore the brake lights and may also release the shift interlock. If the problem remains, also check the brake on/off (BOO) switch.
Conversation Summary
A 1995 Ford Taurus with a recently rebuilt V-8 will not shift out of park without the manual override, and the brake lights do not work. Replacing a fuse temporarily unlocked the shifter, but the fuse blew again and the shifter locked. The owner suspects an electrical problem rather than the transmission. The expert says the brake light switch on the pedal is the likely failure and should be replaced first; the brake on/off switch may also have failed.
