1993 Ford Taurus Brake Lights
MAMAGISTRI
  • 1993 FORD TAURUS
  • 6 CYL
  • FWD
  • 131,000 MILES
My daughter has a 1993 Ford Taurus. She had a problem with the brake lights not coming on and the car not going into gear. I replaced the brake light switch and the pigtail to the switch. All seemed well for a couple of months and now the same thing is happening. I replaced the switch again but this time it didn't make a difference. She still has no brake lights and cannot put the car in gear unless she starts in neutral first. Any ideas on what I can check next?
Wednesday, November 10th, 2010 AT 4:06 PM
BMRFIXIT
  • 19,053 POSTS
Should have power at the switch and if not recheck wiring and fuses
Wednesday, November 10th, 2010 AT 6:54 PM
MAMAGISTRI
Hi;
I did borrow a test light and checked for power. All is good there. I pulled all fuses and checked those too. I am at my wits end with this!
Wednesday, November 10th, 2010 AT 9:15 PM
BMRFIXIT
  • 19,053 POSTS
Should have power at one wire and when step on brakes should have power at the other side(checking at the back of the switch ) if not switch is no good
if have power at both when switch on poblem after the switch. Check wiring harness
let me know
Thursday, November 11th, 2010 AT 5:38 AM
