2001 Ford Taurus Vibration Under Acceleration Fix
ASALFORD
  • 8 POSTS
severe vibration in the front end during heavy acceleration regardless of speed. once the heavy load is removed, the vibration stops. the heavier the acceleration, the worse the vibration. During normal driving or braking the vibration is not present.
When I jack one side of the car up, there seems to be a small amount of play in the wheel and the CV boots seem to be in good shape.
none of the front end compents have ever been replaced.
Feb 12, 2007 at 12:38 AM
2CARPRO JACK
  • 11,533 POSTS
Regardless of how they look you could have a CV joint that is going bad. Does the trans shift properly?
Feb 22, 2007 at 12:19 AM
ASALFORD
  • 8 POSTS
Thanks for reading this post.
Trans appears to shift properly. I have not noticed any slipping.
I am not getting the popping and clicking noises when the wheel is turned that is normally associated with CV joints gone bad.
Is there a good test for CV joints without removing the struts and half shaft?
to get the correct CV shaft, would you happen to know which trans is in the 2001? mine has the 3.0L DOHC ses. It is either a ax4s or ax4n
Feb 22, 2007 at 12:58 AM
ASALFORD
  • 8 POSTS
The diagnosis was right on target. the CV axle was bad. when I was tearing down the passengers side i also noticed generous amount of play in the steering nuckle ball joint. I pressed it out and replaced it as well.
Additional Note: It is EXTREMELY easy to damage the differential seal when trying to get the axle to break free. The best choise was to use a 19mm wrench and put a breaker bar into the closed end side. be sure the open end side rests against the transaxle and not the seal. I damaged mine because the manual said to use a screwdriver. When it does break loose it is gonna fly so, have it secure with wire before you try to break it loose.
Now, I have to pull mine again and replace the differential seal.
Mar 5, 2007 at 6:28 AM
Suggested Repair
Replace the failing front CV axle. Also inspect the steering knuckle ball joint and replace it if there is play. When removing the axle, support it so it cannot fly free and avoid prying against the differential seal; replace the seal if it is damaged.
Conversation Summary
A 2001 Ford Taurus with 120,000 miles vibrated in the front end only under heavy acceleration, with slight wheel play and intact-looking CV boots. The transmission shifted normally and there was no clicking on turns. The expert suspected a failing CV joint. The owner confirmed the passenger-side CV axle was bad, also replaced a loose steering knuckle ball joint, and damaged the differential seal during axle removal, requiring seal replacement.
