Hello, and thank you for a wonderful forum. I have a 2001 Ford Taurus with 160000 miles. While driving to work, at a stop light I noticed some smoke coming from under the hood. After pulling over and examining I noticed oil dripping onto the ground about once every 5 seconds from the right side (passanger side) of the engine. I couldn't see it properly, but it also looked like oil was dripping onto a metal Y-bar shaped part (also on right side) and this was causing the smoke.
To be properly informed before I take to a mechanic, could this be an oil pan gasket leak? Is that a DIY job ( I have a friend who actually has a lift in his home garage). Thank you in advance.
Dec 12, 2006 at 9:30 AM
