2001 Ford Taurus
EMTYONE
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 58,000 MILES
Window switches, mirror control, interior lights do not work.
need to know where do I need to start looking because it is 3 different things. Are they all on the same fuse or different fuses, the owners manual was clear about that. The only fuse I found was a fuse for the window one touch and i'm sure that controls the window switches.
Saturday, January 23rd, 2010 AT 2:04 PM
BMRFIXIT
  • 19,053 POSTS
Check all fuses using a test light or volt meter
if all OK need to have it scanned for codes
looking for B codes
you have battery saver relay and accessory relay that power them too
Tuesday, June 30th, 2020 AT 5:56 PM
