Power windows
165,000 MILES • 6 CYL • FWD • AUTOMATIC
GCONTE
I am experienced mechanic and I should know this but I have been going through some health issues and my brain is a little foggy so I sure could sure use some assistance. I replaced the rear view mirror on the driver side and when I put it back together the windows would not roll up, any of them. There is no power to the windows on any of the switches in the vehicle. I removed the door panel and wiggled the wires and also the wires in the door hinge area and nothing. the power window relay or fuse is not labeled in the manual or anywhere and I am having trouble finding the window power source. Has anyone had any experiences in this area?
May 27, 2017 at 1:41 PM
GCONTE
I figured it out it was fuse f226 which is on the right hand side of the fuse panel four down, on the box under the dash it also controls the dome light I had not realized the dome light was out also until it got dark out and then it struck me. so it is all fixed and that was the problem.
Jun 30, 2020 at 10:53 AM
STEVE W.
  • 15,411 POSTS
Good job. Brain fog is common with mechanics, think it has to do with getting zapped by the ignition system while breathing in carburetor cleaner fumes.
