2000 Ford Taurus P304 Code
RICHARD BEE
My 2000 Taurus has 124,000 miles and I am getting a P304 code. The car has a coil-on-plug ignition system. I had a major tuneup at 105,000. To date, I have replaced the spark plug and the coil. I disconnected the battery when when I replaced the parts and therefore reset the computer to hopefully get rid of the service engine light. However, I'm still getting the service engine light and I can feel the car miss ever so often and then I get the service enginme light back on. Soemtimes the service engine light goes off other times it stays on. I used a Autolite spark plug and a Borg Warner ignition coil.
Any help on what else could be wrong?
Feb 15, 2006 at 5:51 AM
PEPPERMRJ
  • 1,158 POSTS
code P0304 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
Check the connection for the injector. Run some injector cleaner thru a couple tankfulls. I like chevron with techron myself.
Feb 15, 2006 at 12:26 PM
Discussion summary
The poster's 2000 Ford Taurus (124,000 miles) is showing a P304 code and an occasional miss. They say the car has a coil-on-plug ignition, had a major tuneup at 105,000 miles, and have replaced the spark plug (Autolite) and an ignition coil (Borg Warner), then disconnected the battery to reset the computer, but the service-engine light and intermittent miss continue.
Reported outcome: After replacing the plug and coil and resetting the ECU the poster still experiences occasional misfire and an intermittently illuminated service-engine light; no resolution reported.
Read the original discussion
