2000 Ford Taurus Brake Light Stays On
RCLAY79
I own a 2000 Ford Taurus and recently on a road trip the emergency brake light on the instrument cluster came on and remains on as long as the car is started. When checking the manual, it tells me to have the car serviced immediately. Does anyone have any suggestions on what could be causing the malfunction. I would like to try to fix it myself. Thanks.
Apr 14, 2007 at 7:20 AM
NKTIDWEL
  • 7 POSTS
When my brake light came on, it was due to low brake fluid. The float, just kept getting stuck. I put in synthetic brake fluid and haven't had the problem since.
Apr 14, 2007 at 11:20 AM
TAURUSWHEEL
  • 718 POSTS
The parking brake light??? as above said, check your brake fluid level.. if that's fine get down under the dash and check the little parking brake light switch attached to the parking brake pedal, usually they don't turn the light on with parking brake applied, but the other way can hapen too... or are you talking about the yellow abs light???
Apr 14, 2007 at 4:15 PM
MERLIN2021
  • 17,250 POSTS
If you have ABS DO NOT USE synthetic or DOT 5 fluid, it airates in the ABS sytem and will cause brake loss!
Apr 15, 2007 at 2:22 AM
RCLAY79
I went out right after I posted the question and checked the fluid and it was low. Thanks for all of the help comments.
Apr 16, 2007 at 4:47 AM
Suggested Repair
Check the brake fluid level and top it up with the correct fluid if low. Do not use synthetic or DOT 5 fluid if the vehicle has ABS. If the fluid level is normal, inspect the parking brake pedal switch under the dash and confirm whether the warning is the parking-brake light or the ABS light.
Conversation Summary
A 2000 Ford Taurus owner reported that the emergency brake light stayed on whenever the car was running. Replies suggested low brake fluid, a stuck fluid float, or a faulty parking brake switch, and warned against using synthetic or DOT 5 fluid in an ABS system. The owner then checked and found the brake fluid was low.
