1999 Ford Taurus Alternator
195,000 MILES • 6 CYL • 4WD • AUTOMATIC
JARRODSIMPSON2010
I have a 99 ford taurus se that i jus recently replaced the alternator on. We had the alternator checked and they said it was good. When we put jumper cables on the battery it runs but when we take them off it dies completely. We can't figure out wat the problem is. Thanks for your help.
Sep 1, 2010 at 1:44 PM
  • 110,251 POSTS
When you remove the cables and it dies, do the electrical components still work?
Sep 1, 2010 at 1:46 PM
JARRODSIMPSON2010
it dies completely. It has no power to anything.
Sep 1, 2010 at 2:03 PM
  • 110,251 POSTS
Have you checked the main 100amp fuse in the power distribution box under the hood? Also, is the ground to the engine block good?
Sep 2, 2010 at 12:01 AM
