Belt shreds
SHELBYE5689
  • 1999 FORD TAURUS
  • 3.0L
  • V6
  • 87,500 MILES
We had to change the alternator and starter. First, the new alternator only had holes for the double anchor, not the third, single anchor. Does that matter? Second, ever since, the new belts keep shredding; yet, the old belt just squeals. Plus, the tension pulley does not seem to turn now. Where do we start checking, or do we just change the tension pulley assembly? Thanks so much in advance.
Sunday, July 24th, 2016 AT 12:35 PM
SATURNTECH9
  • 30,869 POSTS
What is the VIN number of your car and the part number of the alternator you installed?Also does the belt tensor pulley itself turn if you remove the belt and try to turn the pulley by hand?
Sunday, July 24th, 2016 AT 2:12 PM
SHELBYE5689
The auto parts store showed my brother three alternators that could be used on my car; he chose the one that was most like the old one. The tension pulley does not move on it is own by hand. Thank you.
Sunday, July 24th, 2016 AT 2:37 PM
SATURNTECH9
  • 30,869 POSTS
If the tensor pulley does not turn by hand the the bearing in the pulley is bad. That is probably why the belt is shredding. I would start by fixing that problem and go from there I would just replace the whole belt tensor.
Sunday, July 24th, 2016 AT 2:44 PM
SHELBYE5689
Okay then. Will keep you posted.
Sunday, July 24th, 2016 AT 4:16 PM
SATURNTECH9
  • 30,869 POSTS
Yes please keep us posted.
Sunday, July 24th, 2016 AT 4:35 PM
SHELBYE5689
Hello. My brother finally removed the tension pully to find several strips of the belt wrapped inside. So, he replaced just the pully. But now it's out of alignment, and the belt keeps trying to slip. Is there a way to align it without replacing the whole assembly? Thanks for all always.
Thursday, July 28th, 2016 AT 7:32 PM
SATURNTECH9
  • 30,869 POSTS
There not align able if it's out of alignment with the rest of the pulleys then replace it. Also the new alternator didn't match the old alternator?
Thursday, July 28th, 2016 AT 7:36 PM
