1998 Ford Taurus Fuel Pump Reset
AMAZINGPRINCESS
Where is the reset button located at on the 1998 Ford Taurus?
Mar 10, 2007 at 9:28 AM
TAURUSWHEEL
  • 718 POSTS
Fuel pump reset??? Usually on the right side rear, behind a panel in the trunk, or small access door in wagon.. button will be on top of fuel relay. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Mar 10, 2007 at 2:42 PM
Suggested Repair
Look for the fuel pump reset on the right rear, behind a trunk panel or a small wagon access door. The button is on top of the fuel relay.
Conversation Summary
The owner asked where the fuel pump reset button is on a 1998 Ford Taurus. The expert said it is usually on the right side rear, behind a trunk panel or wagon access door, on top of the fuel relay.
