1998 Ford Taurus Poor Fuel Mileage
CHRIS K
Mfg.: Ford
Model: Taurus
Year: 1998
Engine: 3.0L code "U" Mileage: 125,000
City driving fuel economy has deterioated signficantly about 12 mpg (Highway speed 50mph or greater the fuel economy is great! around 25 mpg).
My main concern is the LT FTRM2 reading is much higher than LT FTRM1 the opposite bank. Everything being equal they both should be reasonalbly close in readings.
I suspect a problem with 1 or 2 injectors leaking or possible OS2 sensors.
One more piece of information, as driving speed increases the LT FTRM2 reading drops significantly but it still is nowhere near LT FTRM1 reading.
Code Scanner reveals the following:
ENGINE SPD(RPM)1150
MAF(LB/M) 0.81
IGN ADV(DEG) 22.0
ST FTRM1(%) -0.8
LT FTRM1(%) -3.1
ST FTRM2(%) 2.3
LT FTRM2(%) 14.8
O2S11(V) 0.525
ST FTRM11(%) 1.6
O2S12(V) 0.745
O2S21(V) 0.535
ST FTRM21(%) 3.9
O2S22(V) 0.825
FRAME: -5 TM: -8.8
Any Ideas on where begin to resolve this issue. Car runs fine, plenty of acceleration, starts easy hot or cold
Oct 20, 2007 at 6:49 AM
MERLIN2021
  • 17,250 POSTS
You might try monitoring how well the 02 sensors are working, especially this one...O2S22(V) 0.825
Oct 20, 2007 at 7:33 AM
Suggested Repair
Monitor O2 sensor operation, especially the bank 2 downstream sensor (O2S22), which was reading high at 0.825V.
Conversation Summary
The owner of a 1998 Ford Taurus 3.0L reports poor city fuel economy of about 12 mpg while highway economy remains about 25 mpg. Long-term fuel trim on bank 2 is much higher than on bank 1, and the owner suspects leaking injectors or O2 sensors. The car otherwise runs and starts well. The expert recommends monitoring O2 sensor function, particularly the high O2S22 reading.
