possible cause
crank sensor,
fuse,
wiring,
coil,
PCM.
SPONSORED LINKS
Wednesday, January 6th, 2010 AT 5:18 PM
SPORTZFAN38
MEMBER
1 POST
Could a aftermarket remote start possibly cause no spark. The coil is pack is testing good and all fuses are good.
Wednesday, January 6th, 2010 AT 10:33 PM
BMRFIXIT
MECHANIC
Some do some dont
if has an alarm system with it
and wired to disable the spark,
but if no alarm just a remote starter it shouldn't effect the spark
in both cases checking wiring would tell
if coil tested OK and no codes my next step would be crank sensor
