1992 Ford Taurus No Spark
XXXV1
  • 5 POSTS
i have ford taurus 92 it is the 3.0 gl motor i am not getting spark
i have replaced the tfi already and what i call a coil
and if you sugjest the crank sentor where would the be locade i am unable to find it
Feb 7, 2007 at 7:24 AM
  • 75,988 POSTS
Where are you checking for spark at the plug wire or coil coil? Do you have power going to the TFI from the ignition
Feb 7, 2007 at 9:38 AM
XXXV1
  • 5 POSTS
i check at the spark plugs and at the coil both nothing in eather spot and as far as the tfi as far as i know i do i can tell i was driving down the rode the car was runnig and it died and i could not get it started again checked for spark and there was nun had a vaulrmetter but it stopped working
Feb 7, 2007 at 9:40 AM
  • 75,988 POSTS
[quote:ae36728905="xxxv1"]i check at the spark plugs and at the coil both nothing in eather spot and as far as the tfi as far as i know i do i can tell i was driving down the rode the car was runnig and it died and i could not get it started again checked for spark and there was nun had a vaulrmetter but it stopped working[/quote:ae36728905]
Investigate the crankshaft pos. sensor if it has.
Feb 7, 2007 at 10:55 AM
XXXV1
  • 5 POSTS
i have looked for that but not sure i am looking in the right place could you give me and idea where it would be if i have one
Feb 7, 2007 at 10:57 AM
  • 75,988 POSTS
[quote:adfda08ec6="xxxv1"]i have looked for that but not sure i am looking in the right place could you give me and idea where it would be if i have one[/quote:adfda08ec6]
Look on the front of the engine where the main pulley or call a shop and ask for the location. Not really familiar with this model.
Feb 7, 2007 at 11:05 AM
XXXV1
  • 5 POSTS
i found out what is was the timing belt or chain broke i wanted to think you for your help thow
Feb 9, 2007 at 9:28 AM
  • 75,988 POSTS
You're Welcome and come again
Feb 9, 2007 at 9:33 AM
Suggested Repair
The no-spark no-start was traced to a broken timing belt or chain, which should be replaced. Earlier checks included spark at the plugs and coil, TFI power, and, if equipped, the crankshaft position sensor at the front of the engine near the main pulley.
Conversation Summary
A 1992 Ford Taurus 3.0 lost spark and would not restart after dying while driving. The owner had already replaced the TFI module and coil and found no spark at the plugs or coil. The expert suggested confirming power to the TFI and checking the crankshaft position sensor, if equipped, near the front pulley, or asking a shop for the location. The owner later reported that the timing belt or chain had broken.
