1997 Ford Taurus Won't Crank
JDUNN
Car is a 97 Taurus GL, it has power, but when you turn the key to the on position, it won't crank. It's making a small click noise, which seems to be coming from a small box next to the battery...any ideas? Or can anyone tell me what that box is?
Oct 9, 2007 at 1:12 PM
BLACKOP555
  • 10,386 POSTS
your battery is dead my good sir. or the terminals are corroded and not making a complete connection. clean up the terminals tighten down the clamps charge the battery or jump it
and you are good to go
Oct 12, 2007 at 1:54 AM
BLACKOP555
  • 10,386 POSTS
yes your radio may be on but, theres not enough juice to crank the engine
Oct 12, 2007 at 1:55 AM
Suggested Repair
Check for a weak battery or poor battery connections. Clean corroded terminals, tighten the clamps, then charge or jump the battery.
Conversation Summary
A 1997 Ford Taurus GL has power but will not crank and makes a small click from a box next to the battery. The expert said the battery is likely dead or the terminals are corroded and not making a complete connection, noting that accessories can still work without enough power to crank. They recommended cleaning and tightening the terminals and charging or jumping the battery.
