1996 Ford Taurus Water pump
RESEJ1
  • 1996 FORD TAURUS
1996 Ford Taurus 6 cyl Two Wheel Drive Automatic
I had water spraying out of one of the hoses that connected to my water pump and my car was over heating. I was wondering do you know what maybe the problem?
Friday, December 11th, 2009 AT 12:13 AM
BLACKOP555
  • 10,371 POSTS
If the hose was spraying out coolant then that could probably be blamed for the overheating. Replace the hose and the clamp and refil the coolant level and run it and see if it overheats.
Friday, December 11th, 2009 AT 2:04 PM
RCDUPO
Try replacing the thermostat, check for plugged radiator.
Saturday, December 12th, 2009 AT 5:43 PM
