HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine Cooling
Leak
SPONSORED LINKS
1996 Ford Taurus anti freeze leak
CASHDEB
MEMBER
1996 FORD TAURUS
6 CYL
2WD
AUTOMATIC
143,000 MILES
I am leaking anti-freeze between the trans and oil pan, the space between the trans and the pan is so small unable to tell where the leak is.
thank you
Wednesday, April 15th, 2009 AT 7:48 PM
MECHANIC
The leak could be coming from a leaky freeze plug behind the engine.
SPONSORED LINKS
Friday, August 21st, 2020 AT 1:40 PM
LARRY35773
MEMBER
Sounds like a freeze plug goodluck
Please
login
or
register
to post a reply.
Related Leak Content
Leaking Antifreeze
Timing Chain Cover Gasket Leaking Antifreeze. Do I Need To Replace The Water Pump And Timing Chain?
Asked by
melvin mutter
1 ANSWER
1996
FORD TAURUS
VIDEO
Cooling System Pressure Test For Leaks
Instructional repair video
GUIDE
Coolant Leak Symptoms
When your car begins to leak coolant the first indicator is the engine will start run hot and possibly overheat. This will be noticed by the driver by observing the...
Leaking Antifreeze
Where Is My Thermostat On My 1996 Ford Taurus? I Have Recently Had A New Water Pump Thurmistat And Gaskit Put On My 1996 Ford Taurus And...
Asked by
leapurvis
1 ANSWER
1996
FORD TAURUS
1996 Ford Taurus Loss Of Coolant
My Ford Taurus, Seems To Leak Antifreeze From The Back Side Of The Motor ( Fire Wall Side ) But I Cant Find Where Its Coming From. Please...
Asked by
Joe Public
1 ANSWER
1996
FORD TAURUS
1996 Ford Taurus Coolant Plug
Engine Mechanical Problem 1996 Ford Taurus 6 Cyl Front Wheel Drive Automatic I Am Considering Purchasing A 96 Or 97 Ford Taurus From A...
Asked by
rustyehs
1 ANSWER
1996
FORD TAURUS
1996 Ford Taurus 3.0l Gl
I Have A Major Water Leak Coming From In Between The Motor And The Bell Housing. Would It Be A Freeze Plug
Asked by
Ronnie Pope
1 ANSWER
1 IMAGE
1996
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Online car repair manuals
