2002 Ford Taurus Heater Core Failure
BRIANSLOSS
I am desperate for help on our 02 Ford Taurus (~120K miles). We are getting ready to replace the fourth heater core in just over 2 years. We always have Ford original parts put in and the service center at our local Ford dealer has been very helpful (charging us for parts only) but still is costing us in terms of car rental and service. Has anyone else had this chronic problem or am I just unlucky? Please help!
Thanks.
Oct 1, 2007 at 1:23 AM
SERVICE WRITER
  • 9,123 POSTS
Electrolysis is a problem with some of the fords. There are TSBs that the dealer should have looked at, ask them if they did. Bad grounds will cause this. Also there can be restrictors put on the inlet side of the heater, although I have only read about them, not having had a problem in our shop with these.
Oct 1, 2007 at 1:32 AM
BOOTDOG
  • 665 POSTS
a good way to stop the electrolysis, is after flushing the entire coolant system out, mix the coolant with distilled water.
Oct 1, 2007 at 10:52 AM
Suggested Repair
Have the dealer check related TSBs and electrical grounds for electrolysis. Flush the cooling system and refill with coolant mixed with distilled water. A heater-core inlet restrictor may also be considered.
Conversation Summary
The owner of a 2002 Ford Taurus reports four heater-core failures in about two years despite using original Ford parts. Experts attribute the problem to electrolysis, often caused by bad grounds, and recommend checking applicable TSBs. They also suggest flushing the cooling system and mixing coolant with distilled water, with a heater inlet restrictor as another possible measure.
