1999 Ford Ranger Lurches Stopping
LOOKINGTOZION
1999 ford ranger 4.0 4x4 automatic supercab. The truck lurches when slowing down to a stop or starting from a stop. It is jerky when stopping and starting. It almost feels like it is down shifting, but I don't think it is. Other than this the transmission shifts fine. The engine runs good. The trans has 80k miles and has a new filter and fluid.
Nov 11, 2007 at 12:39 PM
98RANGERXLT
  • 301 POSTS
Your fluid is probably low start the the truck drive it about five or ten miles then let it idle in park run through all the gears and check the fluid it should be in the cross hatched when you check it
Nov 12, 2007 at 11:51 AM
Suggested Repair
Check the transmission fluid level after driving 5 to 10 miles. With the engine idling in park, shift through all gears, then confirm the fluid is in the cross-hatched range.
Conversation Summary
A 1999 Ford Ranger 4.0 automatic lurches or feels jerky when slowing to a stop and when starting from a stop, though it otherwise shifts normally and the engine runs well. The transmission has 80,000 miles and recently received new fluid and a filter. The expert suggested the fluid may be low and advised checking it hot after a short drive, with the engine idling in park after cycling through the gears.
