1993 Ford Ranger Sloppy Clutch Pedal
GWSADLE
1993 Ford ranger 4 wheel drive 4.3 160,000
The truck sat for a couple of weeks. I noiticed
the clutch pedal was sloppy and the reservoir was low. I added fluid but it's still the same. The clutch worked fine up to this point Do I need to bleed the system? How would I do that? I don't see a slave cylinder. Or could it be something else?
Oct 22, 2007 at 1:37 AM
FAIRRACING31
  • 150 POSTS
The hydraulic system should be bled to remove all air whenever air enters the system. This occurs if the fluid level has been allowed to fall so low that air has been drawn into the master cyclinder. Under normal circumstances, air should not enter the system when the quick-disconnect hydraulic line fittings are disconnected. The procedure is very similar to bleeding a brake system, but depends mainly on gravity, rather than the pumping action of the pedal, for the bleeding effect. 1. Be sure master cyclinder is filled to the top with new brake fluid conforming to specification. 2. Raise the vehicle and place it securely on jackstands to gain access to the bleeder valve, which is located on the left side of the clutch housing. 3. Remove the dust cap which fits over the bleeder valve and push a lenght of clear plastic hose over the valve. Place the other end of the hose into a container. 4. Open the bleeder valve. Fluid will run from the master cylinder, down the hydraulic line, into the release cylinder and out through the clear plastic tube. Let the fluid run out until it is free of bubbles. NOTE: Don't let the fluid level drop too low in the master cylinder, or air will be drawn into the hydraulic line and the whole process will have to be started over. 5. Close the bleeder valve. 6. Have an assistant slowly depress the clutch pedal and hold it. Open the bleeder valve on the release cylinder, allowing fluid to flow through the hose. Close the bleeder valve when the flow stops. Once closed, release the pedal. 7. Slowly press and release the pedal five times, waiting for two seconds each time the pedal is released. 8. Fill the fluid reservoir. 9. The clutch should now be completely bled. If it isn't repeat steps 1-9. 10. Continue this process until all air is evacuated from the system, indicated by a solid stream of fluid being ejected from the bleeder valve each time with no air bubbles in the hose or container. 11. Install dust cap and lower vehicle. 12. Check fluid level.
https://images.2carpros.com/forum/automotive_pictures/103836_bleeder3_1.jpg
Bleeder Valve
Oct 24, 2007 at 9:05 AM
Suggested Repair
Bleed the hydraulic clutch at the bleeder valve on the left side of the clutch housing. Keep the master cylinder filled with new brake fluid and continue until the fluid runs free of bubbles, repeating the pedal-assisted steps if the pedal remains soft.
Conversation Summary
The owner of a 1993 Ford Ranger said the clutch pedal became sloppy after the truck sat for a couple of weeks and the reservoir was low. Adding fluid did not restore normal pedal feel, and the owner could not see a slave cylinder. The expert explained that low fluid can draw air into the master cylinder and recommended bleeding the system at the clutch-housing bleeder until bubble-free fluid flows.
