1995 Ford Ranger Horn Not Working
ALEX7772006
  • 17 POSTS
i have a 1995 ford ranger 2 door
and my horn stop wroking
i opened my hood today and then my friend pushed the horn button on my steering weel and i could hear some clicking in the main fuse box thats in the hood
anyone have suggestions?
and where does horn located i couldnt find it
Nov 10, 2007 at 10:15 AM
BMRFIXIT
  • 19,053 POSTS
[quote:255449d0fe="Alex7772006"]i have a 1995 ford ranger 2 door
and where does horn located i couldnt find it[/quote:255449d0fe]
need a horn
they stick them in the fender behind head light
Nov 10, 2007 at 2:42 PM
ALEX7772006
  • 17 POSTS
[quote:4a04f2655c="BMRFIXIT"][quote:4a04f2655c="Alex7772006"]i have a 1995 ford ranger 2 door
and where does horn located i couldnt find it[/quote:4a04f2655c]
need a horn
they stick them in the fender behind head light[/quote:4a04f2655c]
is it on the drivers side or passanger?
because i have something thats making lots of noise when you go over bumps in the drivers side fender and i cannot find the problem
Nov 10, 2007 at 4:04 PM
Suggested Repair
Test or replace the horn, which is mounted in the fender behind the headlight. Clicking in the underhood fuse box when the button is pressed suggests the relay is working and the horn itself may have failed. Confirm which side the horn is on before chasing the separate fender rattle.
Conversation Summary
The owner of a 1995 Ford Ranger says the horn stopped working. Pressing the horn button produces a click in the underhood fuse box. The expert says a horn is needed and that it is located in the fender behind the headlight. The owner then asks whether it is on the driver or passenger side and mentions a rattle in the driver-side fender over bumps.
