1998 Ford Ranger Heater Stuck on Defrost
MRESCAPE2001
I have a ford ranger truck 1998 with a four cy engine, the heater control will move to all dials but it will only work the defrost on all dials. I have about 127,00 mileage on the truck. Why? :lol:
Mar 11, 2007 at 12:14 PM
FORDTECH1
  • 23 POSTS
check for a vacuum leak in the engine compartment.
Mar 11, 2007 at 12:55 PM
TAURUSWHEEL
  • 718 POSTS
Fordtech is right, defaulting to defrost mode is classic vacuum issue with Fords,, there's a vacuum leak somewhere, also once I ran across where the linkage fell off the blend door, resulting in same..vacuum leak could be at the function control valves, they are combo i believe of electric and vacuum... I had an older Taurus where if you were climbing a long hill at highway speed, it would lose the vacuum supply to the function control and it would revert to the defrost mode, heat a or a\c,, I even tried putting an extra-large vacuum storage tank in the line still no good, the low engine vacuum climbing the hill would take it all away
Mar 12, 2007 at 7:25 AM
Suggested Repair
Check for a vacuum leak in the engine compartment and at the heater function control valves. Also inspect whether the blend door linkage has come off, since loss of vacuum commonly forces Ford systems to stay in defrost.
Conversation Summary
The owner of a 1998 Ford Ranger with a four-cylinder engine said the heater controls move through all settings but airflow stays on defrost. Replies said this is a classic Ford vacuum problem and recommended checking for a vacuum leak, including at the function control valves, and also checking whether the blend door linkage has fallen off.
