1997 Ford Ranger Constant Heat
thanks
jim
Jim
Jim
Suggested Repair
Check under-hood and under-dash vacuum lines and the temperature selector vacuum switch. If the heater-box blend door is broken, replace the heater box or blend-door assembly, often from a salvage yard, rather than attempting a partial repair.
Conversation Summary
The owner of a 1997 Ford Ranger 3.0 reported constant maximum heat on every temperature and air-source setting, while all fan speeds worked and engine temperature was normal. Experts advised listening for blend-door movement, checking for vacuum leaks, inspecting the under-hood vacuum lines and cab selector vacuum switch, and testing the temperature control with an ohmmeter. The owner later identified a broken heater-box blend door, and an expert said repair depends on the break location and that replacing the assembly from a salvage yard is often better.
