1994 Ford Ranger Heater Not Working
FLO21I99
1994 Ford Ranger 3.0L V6 4x2 60,000 miles, manual transmission. Heater is not working. Replaced heater core, thermostat, gasket, coolant and heater hoses. Question is what can be the possible problem if not any of those and if, let's just say for example, I connected the heater hoses (the ones that attach to the heater core) incorrectly does that really matter. :oops: Anyway what is the correct way for the heater hoses to be connected? Is it the left outlet (looking at the engine from the front of the vehicle) of the heater core to the water pump connector or is it to the thermostat connector. Which one goes where? Like I said before I don't know if it really makes a difference but if it does can someone please give me some guidance? And no, I am not really a mechanical type guy. Thanks for your help in advance
Luis
P.S. I have the Haynes repair manual but it's not really much help.
Nov 4, 2006 at 6:01 AM
BOOTDOG
  • 665 POSTS
u might wanna check your selector switch on the dash and make sure that it is switching from hot to cold. it could be that the knob is cracked on the inside and u might just need a knob, or it might be the whole switch assymbley. also check the heater control valve to see if its stuck closed. if so, replace it. and last check for vacuum leaks. i hope the info helps.
Nov 8, 2006 at 3:18 AM
Suggested Repair
Check the dash temperature selector switch (cracked knob or full switch assembly), inspect the heater control valve and replace it if stuck closed, and check for vacuum leaks.
Conversation Summary
A 1994 Ford Ranger owner says the heater still does not work after replacing the heater core, thermostat, gasket, coolant, and heater hoses, and asks whether hose direction matters and which hose connects where. The expert suggests checking the dash hot/cold selector switch, a stuck heater control valve, and vacuum leaks.
