1991 Ford Ranger AC R12 to R134a
WESMAN2440
  • 23 POSTS
hey I need to charge my AC but iv been told by a friend that by law I can't buy the R12 that is required for it any more .......I dont know ......
so do I need to switch out my condenser to a R134a condenser
May 28, 2007 at 3:06 PM
RUDPRO
  • 224 POSTS
You can't buy R-12 anymore. If you want to convert to 134-a, you can buy a kit at an auto parts store with new o-rings and oil. You should also change the accumulator. You have to get most of the old oil out of the system, taking the compressor and other ccomponents out and draining them. Then you have to change all the o-rings on the compressor and the rest of the system. Then you have to follow the proper evacuation, leak test and fill procedure.
May 29, 2007 at 3:05 PM
Suggested Repair
R-12 is no longer available. Convert the system to R-134a with a kit that includes new oil and O-rings, replace the accumulator, drain the old oil from the compressor and other components, replace the system O-rings, then evacuate, leak test, and recharge.
Conversation Summary
The owner of a 1991 Ford Ranger asked whether the condenser must be replaced because R-12 can no longer be purchased. The expert confirmed R-12 is unavailable and recommended an R-134a conversion using a kit, new oil and O-rings, a new accumulator, drained old oil, and proper evacuation, leak testing, and filling.
