Truck won't start and making clicking noise?
ORLFLO
  • 2002 FORD RANGER
  • 6 CYL
  • 4WD
  • 134,000 MILES
Truck won't start and making clicking noise under the steering wheel when the key is out of it. I have checked the battery starter and the generator and there all good. I have also tried to reset the computer & the engine doesnt turn it just clicks once and shuts down power to the dash board lights and radio I think it has something to do with the anti thief but im not sure
Monday, September 27th, 2010 AT 7:42 PM
  • 109,885 POSTS
A clicking starter usually indicates a weak battery or bad connection. Have you checked to make sure battery terminals are clean and tight? Have you checked the ground to the engine block? Starter relay? Have you had the battery load tested?
Monday, September 27th, 2010 AT 10:07 PM
ORLFLO
No its not really a clicking starter the engine doesnt turn the clicking noise is heard under the steering column in the cab of the truck and I have had the battery load tested thanks
Monday, September 27th, 2010 AT 10:10 PM
  • 109,885 POSTS
Locate the relay causing the clicking and switch it with another that has the same part number.
Tuesday, September 28th, 2010 AT 7:37 AM
