2002 Ford Ranger engine suddenly wont start
TROY2608
  • 2002 FORD RANGER
  • 6 CYL
  • 130,000 MILES
Engine ran well, parked truck, got back in truck, wont start, lights work, radio works, battery good, all dash lights remain on without key in ignition, sometimes prior before current problem truck would not turn off with headlights burning, turn off headlights would turn off truck. Tried stsarting truck by crossing screwdriver across solenoid posts, spins starter and engine but still wont crank, turning ignition will not give any response
Monday, May 10th, 2010 AT 10:25 AM
  • 109,885 POSTS
It sounds like an ignition switch problem. When you turn the key, do the dash lights come on now? Does everything other than the no start seem normal?
Tuesday, May 11th, 2010 AT 11:31 AM
TROY2608
Yes, everthing seems normal, except the no start. But I have already replaced the ignition switch under the dash. Thanks for the reply.
Tuesday, May 11th, 2010 AT 1:13 PM
TROY2608
Even after replacing the switch I still have the same problem
Tuesday, May 11th, 2010 AT 1:15 PM
  • 109,885 POSTS
HAve you checked for power to the starter?
Tuesday, May 11th, 2010 AT 9:08 PM
