2002 Ford Ranger coolant leak on backside of motor
DARCY999
Engine Cooling problem
2002 Ford Ranger 6 cyl Four Wheel Drive Automatic
what could be leaking antifreeze from the backside of the motor? The best I can tell is that it looks like its coming from up high where the block and tranny meet. What should i be looking for?
Jan 17, 2009 at 2:40 AM
MIKE H R
  • 3,094 POSTS
first I would check the hoses going into the heater. sometimes they leak and need tightening. If that is not the problem look by the head where it is connected to the engine. If you can not find the leak then you might have to have the coolant system pressure checked to find the leak.
Feb 9, 2019 at 7:58 AM
