HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Overheat
2000 Ford Ranger overheating
NATEJAKE
MEMBER
2000 FORD RANGER
6 CYL
2WD
AUTOMATIC
71,000 MILES
Found collapsed upper hose//What next T-Stat=What causes this?Any other preventive repair Thanks
Wednesday, January 16th, 2008 AT 6:55 PM
BMRFIXIT
MECHANIC
Coolant system flush change thermostat
SPONSORED LINKS
Wednesday, January 16th, 2008 AT 7:08 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
My Engine Is Overheating How Do I Fix It?
My Car Overheat When Ever I Enter The Highway. But If I'm Within The City, It Won't Overheat. What Could Be The Problem?
Asked by
sixtusokolieuzo
2 IMAGES
2010
FORD RANGER
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
Ford 1987 Ranger (engine)exaust Manifold Red Hot
After Starting, Engine Runs Ok For A Minute, And Then Falls Flat. Exaust Manifold Gets Red Hot, But Moter Doesn't Seem Too.I've Changed The...
Asked by
BOZOUSUCK
1987
FORD RANGER
2000 Ford Ranger Engine Stalling
No Leaks In The Air Tube. Code P1121 Changed The Tps, No Change Took It For A Test Ride And It Ran Terrible, Loss Of Power, Now It...
Asked by
wheelchairdude49
6 IMAGES
2000
FORD RANGER
2000 Ford Ranger Stalling And Idling Rough
When Cold It Stalls, Loss Of Power Till It Warms Up. Then Runs Fine. No Codes Or Pending Codes. Stft Is 21.0 And Ltft Is At 3.1. Cant...
Asked by
wheelchairdude49
1 IMAGE
2000
FORD RANGER
My Question Is: 0 Tdc At The Pointer Or 26 Degree Atdc...
Hi, 2000 Ford Ranger 4l V6 220,000 Miles My Vin: 1ftzr15x3ypc03525 I Am Installing A New Camshaft Synchronizer Position Sensor And I Am...
Asked by
michael44a
8 IMAGES
2000
FORD RANGER
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
