1998 Ford Ranger starting and ignition
LILLIEIII
  • 1998 FORD RANGER
  • 4 CYL
  • 18,000 MILES
Turn key on and sarter turns over, sometime the truck wont start, fuel pressure it right, after setting try to start again and it starts right up. Seem to be during a sudden change in weather
Sunday, January 24th, 2010 AT 11:31 AM
  • 109,885 POSTS
Have you checked to see if it getting spark when this happens? Also, if it is temp related, it could have to do with the temp sensor. However, has the check engine light come on?
Tuesday, February 2nd, 2010 AT 9:56 PM
LILLIEIII
  • 15 POSTS
Joe I have seem to solved the problem using an eletronic cleaner on my ignition switch thank you very much and have a great day
Tuesday, February 2nd, 2010 AT 11:43 PM
