Fuel pump won't come on
1994 FORD RANGER
FORD_BOY
  • 13 POSTS
it has a distrubitor on it and looks like it my need replaced i was messing w/ the coil stator and to my knowledge its under the distrubitor i broke a piece off of it trying to get it out it wont come out unless you pull the distrubitor rod i cant get it out how do i do this???
Nov 24, 2020 at 12:52 AM (Merged)
DAVORANGO
My '90 has a similar sounding issue. Small 'pop' under the hood, stopped running. Turned over, had spark, wouldn't start. Changed fuel pump, new pump won't run. On Autoparts Giant I found a PCM relay for $77. Is this what you're talking about? Can't find PCM. Thx.
[quote:a11259cddf="rasmataz"]New/Refurbished PCM with Autoparts GIANT.com will cost about $165.00[/quote:a11259cddf]
CHARLES C CABRAL
Instead of a toggle switch to power fuel pump I rerouted switched power on my 94 2.3l from the next relay from underneath power distribution box to a 4-pin relay using a new fused (10 amp) battery input (30), outputting (87) from new relay to pin (87) on fuel pump relay connection pin with a blade terminal (no relay installed in top port of distro box). Fuel pump comes on and off with key. My PCM is preventing the fuel pump circuit from energizing. Why I have no idea. It works like it did before the problem, engine seems a lot smoother in all rpm ranges. Best it's ran in the 2 years I have had it. I've on occasion up until the problem have smelled a slight wiring burning smell, no smoke but a faint smell. Like when you burn out one of those cheap tweeters in a car stereo setup. Found some slight melting on bottom of fuse box in cab. I repaired that but it was not the cause of the fuel pump power issue.
Apr 30, 2022 at 3:31 PM
Thanks for adding that to this post. This was an older post so they may not benefit from your experience, but I am sure others will in the future.
Thanks, and let us know if we can help you with anything in the future.
Apr 30, 2022 at 11:20 PM
