1993 Ford Ranger
YARBRSH
  • 1993 FORD RANGER
  • 6 CYL
  • MANUAL
  • 89,000 MILES
MY ford truck simply will not start. I have replaced the fuel pump check the gas tank & switch, replced the filters purchased a newcomputer chip. I have spent a $1,000 on trying to getit to run. After I replaced the computer chip It ran for about 2 weeks w/o a problem. Then I went to start it & it won't start. It will turn over but won't start. Is it time I junked it/// Its in good condition I hv been offered $1,000 for it, not running. I NEED transportation. Do you hve any idea what it could be?
Tuesday, April 27th, 2010 AT 7:55 PM
VEGASFARMKID
  • 30 POSTS
If you replaced the chip and it ran. You could very well have a loose plug or a bad/loose ground. I can imagine your frustration. But, double check all your plugs and connections you had taken apart during your diagnostics. Don't scrap it yet.
Tuesday, April 27th, 2010 AT 8:33 PM
LEGITIMATE007
  • 5,121 POSTS
I agree with vegasfarmkid.
Tuesday, April 27th, 2010 AT 8:52 PM
