I just replaced the fuel pump (with sending unit) and im not getting power to pump, but yet im getting power to fuel gague, when I put fuel pump on new battery it works fine, where would the most common wire problem be, to rule the inertia out of equation where is it located at, thank you for any help that can be givin
SPONSORED LINKS
Tuesday, January 8th, 2008 AT 11:25 AM
