1997 Ford Probe My car wont move
1997 FORD PROBE
116,000 MILES • 6 CYL • FWD • AUTOMATIC
FORDPROBEA
I replaced crank shaft censor and now car will not take off. Is it the crank Shaft.
Jul 6, 2009 at 4:58 AM
TIREMSOKING
  • 5 POSTS
You said it wont take off.Are you meaning it wont start?I would check to see if you are getting spark.If you are getting sparkl,it might be a fuel problem.I looked at a Probe that was for sale.It wouldnt start.I looked it over and found there is a reset button for the fuel pump in the the hatch on the left side behind a cover.Just push in the reset button and the car started right up..
Jul 6, 2009 at 5:13 AM
FORDPROBEA
It starts just fine...but if i put it on drive and hit the gas it seems like its on neutral. No matter what gear i put it on
Jul 6, 2009 at 6:02 AM
TIREMSOKING
  • 5 POSTS
It sounds like a transmission problem..Check to see how much transmission fluid is in it.Its probably low.Make sure the linkage is ok,to the tranny.I think some use a cable.
Jul 6, 2009 at 6:26 AM
BEAUWIGGINS
i have the same problem but for a 93'....did you get yours fixed?
Jul 17, 2009 at 6:22 AM
